Joined: 11/4/2020(UTC) Posts: 19  Location: Penfield Thanks: 2 times
I would like to port the entire vMix control screen, Preview, Broadcast, Sound Meters, Presets to a monitor. What is the best way to do this? I need the screen as the operator is seeing it, not just out broadcast screen.
I dont think you can do it inside vmix. You have to duplicate your monitors from windows settings
Originally Posted by: james.b.quinn@gmail.com  I would like to port the entire vMix control screen, Preview, Broadcast, Sound Meters, Presets to a monitor. What is the best way to do this? I need the screen as the operator is seeing it, not just out broadcast screen.
Try the vMix desktop capture (separate app from vMix) or a NDI Local Desktop Capture of Display 1 Input and send it out over your network or that input to extra monitor
Originally Posted by: nikosman88  I dont think you can do it inside vmix. You have to duplicate your monitors from windows settings NDI Desktop Capture!
