Triggers auto add when new input for video or image is created
We have to add lots of images and videos and right now we have to go to each one and copy triggers one by one.
Is there a way to add scripting or settings that will add the trigger or copy them automatically when a new input is added or by input type?
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: aaroninit  We have to add lots of images and videos and right now we have to go to each one and copy triggers one by one.
Is there a way to add scripting or settings that will add the trigger or copy them automatically when a new input is added or by input type? Might be helpfull to tell what these triggers are.
They are repetitive for images:
ontransitionin fullscreenoutput: fade ACTIVE
for videos:
ontransitionin fullscreenoutput: fade ACTIVE ontransitionin AUDIOOFF input(2)
for videos:
ontransitionin fullscreenoutput: fade ACTIVE ontransitionin AUDIOOFF input(2) Confused: there is no trigger option regarding fullscreenoutput i know of
Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
Hi, I agree with Doggy the triggers you mention don't exist so you may want to double check your syntax.
In regard to adding the same triggers to multiple inputs easily, you can copy triggers from one input to another easily using the "copy from" button on the lower left hand corner of the inputs settings page.
Hope that helps!
Yes this is the manual way you do it. But Aaroninit asks if there is an auto way to do it,without the need to do one by one video. I suppose that when he says fullscreen,he means that the video plays fullscreen. Originally Posted by: aaroninit  They are repetitive for images:
for videos:
ontransitionin fullscreenoutput: fade ACTIVE ontransitionin AUDIOOFF input(2) For videos i do this with a videolist. I have a videolist in which i have the videos i want. But i un-check the "play next" button in the list so everytime a video finishes,list is stopped. With this un-checked every video in the list it is like a separate video input but you setup triggers only 1 time You can also make a shortcut to move to previous/next video
