aaroninit
#1 Posted : Sunday, May 1, 2022 8:55:32 AM(UTC)
aaroninit
We have to add lots of images and videos and right now we have to go to each one and copy triggers one by one.
Is there a way to add scripting or settings that will add the trigger or copy them automatically when a new input is added or by input type?
#2 Posted : Sunday, May 1, 2022 2:34:40 PM(UTC)
Might be helpfull to tell what these triggers are.
aaroninit
#3 Posted : Sunday, May 1, 2022 3:17:02 PM(UTC)
aaroninit
They are repetitive for images:
ontransitionin fullscreenoutput: fade ACTIVE
for videos:
ontransitionin AUDIOOFF input(2)
#4 Posted : Sunday, May 1, 2022 4:19:24 PM(UTC)
for videos:
Confused: there is no trigger option regarding fullscreenoutput i know of
TobinT
#5 Posted : Sunday, May 1, 2022 9:48:54 PM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
I agree with Doggy the triggers you mention don't exist so you may want to double check your syntax.
In regard to adding the same triggers to multiple inputs easily, you can copy triggers from one input to another easily using the "copy from" button on the lower left hand corner of the inputs settings page.
Hope that helps!
nikosman88
#6 Posted : Monday, May 2, 2022 4:18:17 AM(UTC)
nikosman88
Greece
Yes this is the manual way you do it. But Aaroninit asks if there is an auto way to do it,without the need to do one by one video. I suppose that when he says fullscreen,he means that the video plays fullscreen.
for videos:
For videos i do this with a videolist. I have a videolist in which i have the videos i want. But i un-check the "play next" button in the list so everytime a video finishes,list is stopped. With this un-checked every video in the list it is like a separate video input but you setup triggers only 1 time
You can also make a shortcut to move to previous/next video
