RTV
#1 Posted : Sunday, May 1, 2022 4:20:56 AM(UTC)
RTV
Hello All,
Is it possible to fade between inputs, on output 2. I'm using the latest versions of both vmix, and panel builder.
Best to all
#2 Posted : Sunday, May 1, 2022 4:37:29 AM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
Originally Posted by: RTV Go to Quoted Post
Hello All,
Best to all
depends what you have set to output2 (standard it's the same as output1)
Use a mix input as output2 if you dont want it to be the standard output and be able to do transitions between inputs
RTV on 5/1/2022(UTC)
RTV
#3 Posted : Sunday, May 1, 2022 6:10:02 AM(UTC)
RTV
I have output 2 set as output. NDI is on.
#4 Posted : Sunday, May 1, 2022 6:23:04 AM(UTC)
Please refrase you question or intention ( don't see the relation between first post and this one)
TobinT
#5 Posted : Sunday, May 1, 2022 10:40:33 PM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
On the add input button click the arrow (not the main button) and add a mix input. Route this mix input to your output 2. You can then perform transitions on mix input 2 that will go out your output 2.
thanks 1 user thanked TobinT for this useful post.
RTV on 5/3/2022(UTC)
