Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hello All,
Is it possible to fade between inputs, on output 2. I'm using the latest versions of both vmix, and panel builder.
Best to all
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Best to all ' depends what you have set to output2 (standard it's the same as output1) Use a mix input as output2 if you dont want it to be the standard output and be able to do transitions between inputs
I have output 2 set as output. NDI is on.
Originally Posted by: RTV  I have output 2 set as output. NDI is on.
Please refrase you question or intention ( don't see the relation between first post and this one)
Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
On the add input button click the arrow (not the main button) and add a mix input. Route this mix input to your output 2. You can then perform transitions on mix input 2 that will go out your output 2.
 1 user thanked TobinT for this useful post.
