Hardware Compatibility
Capture resolution is not supported by this device...
Joined: 4/6/2022(UTC) Posts: 31  Location: Los Angeles Thanks: 3 times
I have a pocket 4k camera connected to a cam link 4k going into my DELL ALIENWARE LAPTOP into USB 3.0 port, but I am getting a VMIX error saying I can only select Full-HD-Resolution 1080p.... Higher resolution is not supported. I want to record in 4096x2160 What can be the reason for that? Do I need a computer with really powerful hardware to get this working, or is this an issue of settings in vMix? I am simply using VMIX to record youtube videos, not to stream. AddNewInput.The following are supported: 1920x1080 NTSC 29.97p MJPG 1920x1080 NTSC 29.97p MJPG Unspecified error Thanky you for your help! MY LAPTOP SPECS: ALIENWARE AREA 51-M Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz 64.0 GB RAM 64-bit operating system, x64-based processor WINDOWS 11 PRO p.s. I also tried connecting the POCKET 4K into the ATEM MINI PRO ISO, and same error. SCREEN SHOT (also why does it say 2160p in bottom left corner in green, if it is not allowing it?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
If you are trying to capture 4k content, make sure you are selecting 3860x2160p rather than 4096x2160. It took me half an hour to realize that 4096x2160p is not the standard 4k resolution and is not supported by the El Gato card.
