GT
Looping logo
I have a logo that sits on the bottom left corner the whole show. I use a GT Title created with an image. Now I would want that logo to mix to another one (staying at the same place) continuously every 10 seconds. I have tried different things having my two logos on 2 layers of a title, but I cannot seem to figure the way to have them fading continuously to one another. Help please...
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thank you, but I do not see how I can create a loop from 2 jpegs with Image Sequence
Originally Posted by: YvesT  Thank you, but I do not see how I can create a loop from 2 jpegs with Image Sequence
they need to have the same filename with an additional sequencial number ( see helpfiles) of course one can use a script too replacing the image at set intervals
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
I think the input of photos would be fine, you can put the logos you want and then pass one after another by establishing the second the type of transition and delay of the same, then you give it position and size to the input and that's it friend, it's a basic way to do it, is my humble advice translated from spanish to english by google
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
Maybe I think to simple... - Add input --photos (select a folder, not a file to use it as slideshow) - Right-Click on that input to change slideshow settings... You can change transition time, effect and duration... For example, the logo in the bottom left corner - it changes every 10 seconds
GT
Looping logo
