YvesT
#1 Posted : Friday, April 15, 2022 5:21:59 AM(UTC)
YvesT
Canada
I have a logo that sits on the bottom left corner the whole show. I use a GT Title created with an image.
Now I would want that logo to mix to another one (staying at the same place) continuously every 10 seconds.
I have tried different things having my two logos on 2 layers of a title, but I cannot seem to figure the way to have them fading continuously to one another.
Help please...
#2 Posted : Friday, April 15, 2022 11:04:48 AM(UTC)
YvesT
#3 Posted : Wednesday, April 20, 2022 12:14:23 AM(UTC)
YvesT
Canada
Thank you, but I do not see how I can create a loop from 2 jpegs with Image Sequence
#4 Posted : Wednesday, April 20, 2022 1:44:19 AM(UTC)
they need to have the same filename with an additional sequencial number ( see helpfiles)
of course one can use a script too replacing the image at set intervals
Papo
#5 Posted : Thursday, May 12, 2022 2:05:59 AM(UTC)
Papo
Peru
I think the input of photos would be fine, you can put the logos you want and then pass one after another by establishing the second the type of transition and delay of the same, then you give it position and size to the input and that's it friend, it's a basic way to do it, is my humble advice
translated from spanish to english by google
Mari
#6 Posted : Thursday, May 12, 2022 4:16:47 AM(UTC)
Mari
Netherlands
Maybe I think to simple...
- Add input --photos (select a folder, not a file to use it as slideshow)
- Right-Click on that input to change slideshow settings...
You can change transition time, effect and duration...
For example, the logo in the bottom left corner - it changes every 10 seconds
