Ticker with Google Sheet data source only displaying one column
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all,
I have a Google sheet data source that I want to use for a single line scrolling ticker.
The Google Sheet contains three columns for each event. For example
Column 1 has the Team v Team info Column 2 has the game time info Column 3 has the venue info
When creating the data source, I only get the option to display one column. So the ticker ends up just showing the Team v team info before moving onto the next team v team in the next row on the sheet. How can I display All three columns after each other for each row before moving onto the next row?
Thanks By combining the 3 columns into one (GS can do that to another column or sheet for example)
Thanks By combining the 3 columns into one (GS can do that to another column or sheet for example) Really? Sound like a pretty basic limitation of data sources if everything needs to be in one column. Then the sheet isn’t easily editable ?? Surely data sources can look across multiple columns?
Really? Sound like a pretty basic limitation of data sources if everything needs to be in one column. Then the sheet isn’t easily editable ?? Surely data sources can look across multiple columns? Sure a data source can look accross multiple columns for different text fields in a title and such, ticker only has one such field. Off course you could write a script that changes the column to be displayed inthat one field and than advance tothe next row , or you could convert rows to collumns (data source option) and just go through the collumns . If you can not edit the sheet ( see vid below) you can dothe same with a vMix script and send to the title .. https://www.spreadsheetc...olumns-in-google-sheets/
