Richard Archer
#1 Posted : Sunday, April 10, 2022 6:01:07 AM(UTC)
Richard Archer
When I fade into my next scene, can I have the vMix program call up a camera preset? For instance, if the present scene is a wide angle shot and I fade into the next scene that calls for a zoomed-in closeup, can I have the vMix program activate camera preset #6 which would be the closeup?
mavik
#2 Posted : Sunday, April 10, 2022 8:14:23 AM(UTC)
mavik
Create a virtual shot of the both positions/ptz presets and use them as a normal shot.
Richard Archer
#3 Posted : Sunday, April 10, 2022 12:34:10 PM(UTC)
Richard Archer
Thank you for the input. I will check it out.
