Joined: 4/6/2022(UTC) Posts: 3   Location: Tool, Texas Thanks: 1 times
When I fade into my next scene, can I have the vMix program call up a camera preset? For instance, if the present scene is a wide angle shot and I fade into the next scene that calls for a zoomed-in closeup, can I have the vMix program activate camera preset #6 which would be the closeup?
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Create a virtual shot of the both positions/ptz presets and use them as a normal shot.
Thank you for the input. I will check it out.
