HULK622
#1 Posted : Thursday, March 24, 2022 1:26:03 PM(UTC)
HULK622
China
I am using two Logitech c920e USB cameras, but only one camera can be added in vmix. Adding the other will prompt that the system resources are insufficient
I try to use OBS discovery to add these two USB cameras. Is vmix possible to solve this problem
mjgraves
#2 Posted : Friday, April 1, 2022 6:16:30 AM(UTC)
mjgraves
With the cameras left to default settings you are most likely overloading the USB bus.
Be sure to set the video encoding for the cameras to MJPEG. That will reduce the bandwidth required for each stream. Using MJPEG you can pass 2 x 1080p30 streams over a USB2 bus.
melody
#3 Posted : Friday, April 1, 2022 9:08:51 AM(UTC)
Rank: Guest
Groups: Guests
as an addition of what mjgraves said, connect usb cameras the most separate you can
mjgraves
#4 Posted : Tuesday, April 5, 2022 1:58:52 AM(UTC)
mjgraves
FWIW, I've used up to four webcams on a single computer. All operating at 1080p30 using MJPEG.
https://www.mgraves.org/...ms-on-a-single-computer/
nikosman88 on 4/5/2022(UTC)
mavik
#5 Posted : Tuesday, April 5, 2022 3:00:21 AM(UTC)
mavik
Most USB ports are shared on the same bus. You need seperate USB-busses and you will have the necessary bandwidth.
mjgraves
#6 Posted : Saturday, April 9, 2022 7:29:43 AM(UTC)
mjgraves
If you select MJPEG for the webcams, you can have three connected at 1080p30 on the same USB 2 bus.
