NicholasBates
#1 Posted : Thursday, April 7, 2022 4:11:42 PM(UTC)
NicholasBates
I cant see where to go from here?
Hey man,
Cant get the code to work, can i get your assistance?
Starting Script "Timestamp"
Script 'Timestamp' Error Line 8: Object reference not set to an instance of an object.
Stopping Script "Timestamp"
Originally Posted by: elgarf Go to Quoted Post
You can use script if you have 4K or Pro version.
Code:
'Text file for time marks
dim FILENAME = "D:\out.txt"
'Get recording duration
dim xml = API.XML()
x.loadxml(xml)
dim Duration = integer.parse((x.SelectSingleNode("//recording/@duration").Value))
dim Second = math.floor(Duration mod 60)
dim Minute = math.floor((Duration / 60) mod 60)
dim Hour = math.floor((Duration / (60 * 60)) mod 60)
'Write recording duration to file
System.IO.File.AppendAllText(filename, string.format("{0:00}:{1:00}:{2:00}"&Environment.NewLine, Hour, Minute, Second))
#2 Posted : Thursday, April 7, 2022 4:27:59 PM(UTC)
why double post ? (answer in the other one)
NicholasBates
#3 Posted : Thursday, April 7, 2022 4:29:59 PM(UTC)
NicholasBates
More likely to get a response sooner....
#4 Posted : Thursday, April 7, 2022 4:59:21 PM(UTC)
Right , wrong section ( not a feature request) and making it harder for others having a similar issue to search and find an possible answer and by #####
