I cant see where to go from here?
Hey man,
Cant get the code to work, can i get your assistance?
Starting Script "Timestamp" Script 'Timestamp' Error Line 8: Object reference not set to an instance of an object. Stopping Script "Timestamp"
Originally Posted by: elgarf Go to Quoted Post You can use script if you have 4K or Pro version.
Code: 'Text file for time marks dim FILENAME = "D:\out.txt"
'Get recording duration dim xml = API.XML() dim x as new system.xml.xmldocument x.loadxml(xml) dim Duration = integer.parse((x.SelectSingleNode("//recording/@duration").Value))
dim Second = math.floor(Duration mod 60) dim Minute = math.floor((Duration / 60) mod 60) dim Hour = math.floor((Duration / (60 * 60)) mod 60)
'Write recording duration to file System.IO.File.AppendAllText(filename, string.format("{0:00}:{1:00}:{2:00}"&Environment.NewLine, Hour, Minute, Second))
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
why double post ? (answer in the other one)
More likely to get a response sooner....
Originally Posted by: NicholasBates  More likely to get a response sooner.... Right , wrong section ( not a feature request) and making it harder for others having a similar issue to search and find an possible answer and by #####
