Egriswold
#1 Posted : Wednesday, June 4, 2014 5:43:03 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Would like to see gradient wipe transitions based on black to white gradients with a simple pop out selection window.
Plus have a reversible check box, edge softness control.
This would also give ability to create custom gradients from images for our own transitions.
thanks 1 user thanked Egriswold for this useful post.
madness on 6/5/2014(UTC)
madness
#2 Posted : Thursday, June 5, 2014 9:36:36 AM(UTC)
madness
+1
Bardos59
#3 Posted : Thursday, June 5, 2014 10:48:07 AM(UTC)
Rank: Guest
Groups:
This is exactly what I was talking about when I mentioned an Effect pallett in vMix....where all the Effects are shown at the same time, allowing the users to select the transition in one go...rathen than opening seperate effects to select the one you want
#4 Posted : Thursday, June 5, 2014 12:22:58 PM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
Can you explain in more detail what you mean Bardos59?
In vMix there are four configurable transition slots and it only takes 1 click to configure them.
sontoloyo
#5 Posted : Thursday, June 5, 2014 1:08:53 PM(UTC)
sontoloyo
Malaysia
It would be great news, if vMix add these features.
Killerhands
#6 Posted : Thursday, June 5, 2014 2:17:07 PM(UTC)
Killerhands
This sounds like a great idea!
Bardos59
#7 Posted : Thursday, June 5, 2014 6:35:09 PM(UTC)
Rank: Guest
Groups:
What I mean, is that for each transition, there a few variables, and if all the variables are displayed, similar to the image, there would hardly, if any reason to have to open settings to make adjustments, other than duration
In Livestream, VJDirector2, and Cutfour, when I select the Transition Tab, all the variations of a transition is shown, not so in vMix....when I select wipe, I just get a straight vertical wipe..In the image shown, you will notice that there different types of wipes, and directions, so when the pallet opens, all are seen, so the user only has to click on the one needed...The user can adjust the softness of the edges of wipe transitions etc.....this would be a great asset....I know it will take some time, but if this could be implimented by the launch of vMix13, that would be a great leap ahead of anything out there..
In Livestream, VJDirector2, the transitions are labeled just as in vMix, but when I click on wipe, all the variables of wipe is there, same with each type of transition.
#8 Posted : Thursday, June 5, 2014 8:15:12 PM(UTC)
So what you're saying is you want additional transition options?
That's a bit different to just wanting to change the UI, as the transitions don't have parameters that can be changed
They are all implemented separately.
Egriswold
#9 Posted : Friday, June 6, 2014 10:10:22 AM(UTC)
Egriswold
Not being a programmer I really don't know how difficult this would be to implement.
Main idea was just a single wipe transition that is based on a gradient gray scale image.
So if there is a folder with a verity of gray scaled gradient images gives the ability to have unlimited wipes or transitions in one.
Usually there is a thumb nail jpg (low res) for easy browsing and the higher res version in a TGA or PNG for program usage.
This type of wipe has been around in most editors for a very long time.
There are even programs dedicated to creating these images for custom wipes in NLE's
amsudeen on 6/6/2014(UTC)
#10 Posted : Friday, June 6, 2014 10:25:13 AM(UTC)
Interesting, that sounds like a great approach to adding
new transitions without needing to code every single one (as I do now)
Have you found any online reference documentation on how these work?
amsudeen
#11 Posted : Friday, June 6, 2014 10:50:46 AM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
Egriswold thanks a lot. this type transition many time i ask to admin. but no response.
may be not understand admin.
but, you do very clearly explain great.
this concept admin can check :
http://www.pixelan.com/sm25/intro.htm .
the same time try alpha matte or luma matte : check http://www.digitaljuice....ts/products.asp?pid=3508
thanks 1 user thanked amsudeen for this useful post.
madness on 6/6/2014(UTC)
Egriswold
#12 Posted : Friday, June 6, 2014 11:23:25 AM(UTC)
Egriswold
From my understanding its based on 256 steps from 0 --> 255
With 0=black and 255=white and each step creates a level of transparency.
So if its a image like this
The wipe would be course only having 15 steps.
Versus an image like this, with 256 steps and no apparent banding would give a very smooth wipe from inside to outside
or reverse.
Hope this helps
madness
#13 Posted : Friday, June 6, 2014 3:48:44 PM(UTC)
madness
Those Digital Juice Vignettes & Transwipes are what I'm talking about, in .mov file format. I'm hoping that vMix 13 will be able to use these.
amsudeen
#14 Posted : Monday, June 16, 2014 8:31:11 AM(UTC)
amsudeen
we are very expected this function in vmix 13 (gradient wipe transitions)?
we are announce our customer. ( we are dealer in india )
ovinas
#15 Posted : Monday, June 16, 2014 11:03:08 AM(UTC)
ovinas
Don't sell (your) expectations! Also I never saw this anywhere announced for version 13.
madness
#16 Posted : Thursday, June 11, 2015 9:05:16 AM(UTC)
madness
Bump...
Still hoping to see this someday...
mjgraves
#17 Posted : Friday, July 3, 2015 5:56:02 PM(UTC)
mjgraves
Is there anything in WebGL or JQuery-ish stuff that could be leveraged to create an extensible transition capability?
Michael
wwdv
#18 Posted : Sunday, January 15, 2017 12:16:24 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
madness wrote:
Bump...
+1
Peter B
#19 Posted : Sunday, January 15, 2017 7:37:02 PM(UTC)
Peter B
You can make custom wipes now using the key/fill input but having them integrated as transition presets using
user made animated masks would make it a lot easier. Similar to a stinger in implementation.
http://forums.vmix.com/d....aspx?g=posts&t=6706
