External Titles - Alpha Channel Support / Formats
Joined: 5/6/2020(UTC) Posts: 15  Location: NYC Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I watched all the tutorials on the GT Title Designer. Generally a very solid platform. There was some mention of external titles only being supported on Pro/4K. I didn't see anything in the user interface for that.
I did try to bring in a title that was built in AfterEffects and rendered in ProRes 4444 with Alpha. If I bring it in as a video input with the 'alpha' channel box checked, it doesn't seem to work.
What codecs does VMix support in terms of alpha channel for external titles and/or video clips?
Thanks, Jan
Try .mov with an alpha channel.
GT Title designer will import .psd files, image files but not video.
"There are two editions of the designer, Standard and Advanced, each with a different set of features as described below:
Standard
GPU accelerated titles and graphics Add Text, Rectangles, Ellipses, Images, 3D Text and Tickers 4-way Tickers allow movement left to right, right to left, top to bottom, bottom to top at a customisable speed. Supports an unlimited number of layers and groups (up to GPU memory limits) Supports all Windows compatible fonts and languages Powerful text formatting including auto size, auto shrink, word wrapping and auto upper case. Shadow, Reflection, Skew, Crop and Mask effects Fully integrated into vMix including support for Data Sources and vMix Social
Advanced
All the features in Standard plus:
Add animation/transition effects to all objects and layers TransitionIn, TransitionOut animations Continuous animation for constant animation effects such as rotation and gradient/texture offsets DataChangeIn, DataChangeOut animations to occur before and after text or image data changes Page1-10 animations for multi-step animation triggering Import PSD files and convert any text elements into data driven objects
Standard is included with all editions of vMix, Advanced is available in 4K and Pro."
Joined: 7/10/2018(UTC) Posts: 9 Location: Netherlands
I'm currently facing the same issue, i have a whole bunch of overlays that are rendered in proses 4444+alpha but these files put a considerable strain on the machine. I tried convertering them to DXV + alpha, but that codec doesnt seem to play with nice with vMix. Does anyone have any tips on how to produce low cpu animated overlays with alpha?
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Install the NDI tools,  newtek-alpha.png (3kb) downloaded 11 time(s).Steve
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Any progress on this topic?
It's been two years and I'm having issues bringing in videos with industry standard codecs that include an alpha channel into vMix.
I have had some success with webM files
