Streaming with 2 formats, is it possible?
Joined: 10/27/2020(UTC) Posts: 38  Location: Porto Alegre Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
Hey guys,
Does anyone here know if there is a way within vMix to send a signal to two servers, but with different formats?
Example: - Signal for Youtube at 29.97p or 59.94i (depending on the project) - Signal to client server at 50i
I ask if it is possible without using another program like OBS, or even another instance of vMix, to send signals with different formats.
I have a demand for sending football games, where one will be for the YT channel and another for a server of a betting site, which in this case, would be for Russia. As they work in PAL (50i), I believe that sending in 29.97p or 59.94i (NTSC), there may be a conflict.
If anyone can shed some light, I'd appreciate it!
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Don't think they should be betting right now
You can try to go to settings-->external output-->external 2 and change there the format you want. Then go to stream-->2-->ouality gear icon and select at video source output 2. And test to see,if works like you need
