samirbridi
#1 Posted : Wednesday, March 30, 2022 3:14:41 AM(UTC)
samirbridi
Brazil
Hey guys,
Does anyone here know if there is a way within vMix to send a signal to two servers, but with different formats?
Example:
- Signal for Youtube at 29.97p or 59.94i (depending on the project)
- Signal to client server at 50i
I ask if it is possible without using another program like OBS, or even another instance of vMix, to send signals with different formats.
I have a demand for sending football games, where one will be for the YT channel and another for a server of a betting site, which in this case, would be for Russia. As they work in PAL (50i), I believe that sending in 29.97p or 59.94i (NTSC), there may be a conflict.
If anyone can shed some light, I'd appreciate it!
#2 Posted : Wednesday, March 30, 2022 4:04:29 AM(UTC)
Don't think they should be betting right now
nikosman88
#3 Posted : Wednesday, March 30, 2022 6:54:33 AM(UTC)
nikosman88
Greece
You can try to go to settings-->external output-->external 2 and change there the format you want. Then go to stream-->2-->ouality gear icon and select at video source output 2. And test to see,if works like you need
