show output in vb.net project
Hello, im looking how can i show in my vb.net form output of vmix. Its possible?
thanks
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: bgapmi  Hello, im looking how can i show in my vb.net form output of vmix. Its possible?
thanks like this ?
Originally Posted by: doggy  Originally Posted by: bgapmi  Hello, im looking how can i show in my vb.net form output of vmix. Its possible?
thanks like this ? im looking how show vmix output inside one vb.net form. Play one video i know, but now how show vmix output. thanks
Originally Posted by: bgapmi  Originally Posted by: doggy  Originally Posted by: bgapmi  Hello, im looking how can i show in my vb.net form output of vmix. Its possible?
thanks like this ? im looking how show vmix output inside one vb.net form. Play one video i know, but now how show vmix output. thanks Maybe check out the NDi SDK to display a NDI feed of your output to a form
hi, any place where see any sample?
thanks
Originally Posted by: bgapmi  hi, any place where see any sample?
thanks The sdk has samples
Originally Posted by: doggy  Originally Posted by: bgapmi  hi, any place where see any sample?
thanks The sdk has samples sorry my ignorance, where can i locate those samples, i cant locate thanks
Originally Posted by: bgapmi  Originally Posted by: doggy  Originally Posted by: bgapmi  hi, any place where see any sample?
thanks The sdk has samples sorry my ignorance, where can i locate those samples, i cant locate thanks have you downloaded the SDK ?
hi, no, i cant locate it.
do you have url?
thanks
hi, sorry my ignorance, but i cant do this.
somebody can help me? im disposed to pay for it.
thanks
thanks Might be helpfull to tell the purpose of this need
thanks,
we have one software that manages visual content, and we want include vmix output to our software. For it, im looking how can i show vmix output directly in one vb.net form.
thanks
hi, if somebody can do, please contact me to bgapmi (a) gmail dot com.
of course, i can pay for it.
thanks
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
if you are a programmer you can do it, I know the basics of vb but it seems to me that with a directshow you could do it, look for an example of a webcam using directshow because vMix seems to me that it uses this medium in one of its outputs, that is to say no ndi no srt, now if you want you can use ndi as they say above, NDI brings examples in its SDK, if you don't work in C++, there is another simpler one that works under the WPF environment or maybe you handle winForms, but anyway the examples that brings the NDI SDK are understandable is also there in VB.Net. Translated from Spanish to English by Google
Originally Posted by: Papo  if you are a programmer you can do it, I know the basics of vb but it seems to me that with a directshow you could do it, look for an example of a webcam using directshow because vMix seems to me that it uses this medium in one of its outputs, that is to say no ndi no srt, now if you want you can use ndi as they say above, NDI brings examples in its SDK, if you don't work in C++, there is another simpler one that works under the WPF environment or maybe you handle winForms, but anyway the examples that brings the NDI SDK are understandable is also there in VB.Net. Translated from Spanish to English by Google Hi Papo ... hola! You can do? please, send me private message. Im spanish, we can talk about it thansk
si me lees, mandame email a bgapmi arroba gmail punto com y hablamos de si puedes hacerlo y precio.
gracias
