LTF
#1 Posted : Tuesday, March 22, 2022 12:12:28 AM(UTC)
LTF
Hello everyone,
I am using Vmix to trigger a slide show of video clips. Whenever I transition to a video clip via a cut, the clip will flash a later portion of the clip before jumping to the beginning. Do you have any suggestions about how to get Vmix to reliably play each clip from the beginning?
Thanks so much!
sinc747
#2 Posted : Thursday, March 24, 2022 6:24:21 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Are the video clips at the beginning of the clip when you transition to the clip? The clip(s) may need to be "restarted" before transitioning.
- Tom
Roy Sinclair
#3 Posted : Thursday, March 24, 2022 6:49:48 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: LTF Go to Quoted Post
Hello everyone,
Thanks so much!
Do you have the "Automatically Restart with transition" option for the video turned on? Don't even need to add a trigger for that.
