Hello everyone, I am using Vmix to trigger a slide show of video clips. Whenever I transition to a video clip via a cut, the clip will flash a later portion of the clip before jumping to the beginning. Do you have any suggestions about how to get Vmix to reliably play each clip from the beginning?
Thanks so much!
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Are the video clips at the beginning of the clip when you transition to the clip? The clip(s) may need to be "restarted" before transitioning.
- Tom
Joined: 11/23/2020(UTC) Posts: 242  Location: Wichita Thanks: 11 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: LTF  Hello everyone, I am using Vmix to trigger a slide show of video clips. Whenever I transition to a video clip via a cut, the clip will flash a later portion of the clip before jumping to the beginning. Do you have any suggestions about how to get Vmix to reliably play each clip from the beginning?
Thanks so much! Do you have the "Automatically Restart with transition" option for the video turned on? Don't even need to add a trigger for that.
