FlorinU
#1 Posted : Wednesday, March 23, 2022 12:47:26 AM(UTC)
FlorinU
Romania
Could anyone write me a few lines of script to change the color of a text based on the value of another text, please?
Source text should be the required hex code.
Thank you!
#2 Posted : Wednesday, March 23, 2022 2:10:46 AM(UTC)
Thank you!
Code:
API.Function("SetTextColour",Input:="Titlename",SelectedName:="textfield",Value:=Input.Find("Titlename").Text("thecolour.Text") )
FlorinU
#3 Posted : Wednesday, March 23, 2022 2:42:50 AM(UTC)
FlorinU
Romania
API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA",Value:=Input.Find("TEAMS").Text("ColourTeamB.Text"))
Value in ColorTeamB.Text is #FE1F41
Nothing happens :(
#4 Posted : Wednesday, March 23, 2022 2:46:19 AM(UTC)
Nothing happens :(
Just a guess based on so much information given like a screenshot of the title editor and such: is this really the name of the textfield ? "ColorTeamA"
FlorinU
#5 Posted : Wednesday, March 23, 2022 2:54:00 AM(UTC)
FlorinU
Romania
[img=https://qf70pfk.sharing.bublup.com/ui/landing_page?item_id=001-i-3e9cdee6-2b77-4f67-9564-255314dd41e3]Snap[/img]
#6 Posted : Wednesday, March 23, 2022 3:04:49 AM(UTC)
Like i said ( guessed) before , it's not ColorTeamA !
look at what you used for the B one ;-)
FlorinU
#7 Posted : Wednesday, March 23, 2022 4:06:22 AM(UTC)
FlorinU
Romania
OK, the code is this:
API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamB.Text"))
Value in B is: #F91F41
And A gets an 8 zeroes Hex code that sets alpha 0.
https://qf70pfk.sharing....2-4463-869a-626e2bbcc708
I am stuck here for 5 days.
Any idea?
#8 Posted : Wednesday, March 23, 2022 4:23:30 AM(UTC)
Any idea?
you want to have the text in ColorTeamA.Text to be the color that you specified by code in ColourTeamB.Text. this is what this script line is doing. are you running/excecuting the script ?
On the other hand if you want the color of the text to match the code that is written in the text field then use the same textfield twice
Code:
API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamA.Text"))
FlorinU
#9 Posted : Wednesday, March 23, 2022 7:30:27 AM(UTC)
FlorinU
Romania
I need option A
Yes, I am running/executing the script, that's exactly what gets me to the 8 zeroes
Would you give it a try at that script?
Thanks.
F
#10 Posted : Wednesday, March 23, 2022 9:22:22 AM(UTC)
Thanks.
F
Any Script i post has been tested first!
The result you are getting does not make sense , or some information is missing in what you are doing or trying to do
dmwkr
#11 Posted : Wednesday, March 23, 2022 2:21:34 PM(UTC)
dmwkr
Any idea?
Hint: Don't mix American and British English in scripts! ;)
thanks 2 users thanked dmwkr for this useful post.
doggy on 3/23/2022(UTC), FlorinU on 4/7/2022(UTC)
FlorinU
#12 Posted : Thursday, April 7, 2022 4:48:50 AM(UTC)
FlorinU
Romania
Rookie mistake, my bad, now I understand why suddenly it started working (no colo(ur) in the names)
However, vMix has this also mixed in the colo(u)r functions for Title: "SetColor" and "SetTextColour" :)
Thanks for the help!
