Joined: 4/22/2019(UTC) Posts: 8  Location: BUCURESTI Thanks: 1 times
Could anyone write me a few lines of script to change the color of a text based on the value of another text, please? Source text should be the required hex code. Thank you!
Originally Posted by: FlorinU  Could anyone write me a few lines of script to change the color of a text based on the value of another text, please? Source text should be the required hex code. Thank you! Code:API.Function("SetTextColour",Input:="Titlename",SelectedName:="textfield",Value:=Input.Find("Titlename").Text("thecolour.Text") )
API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA",Value:=Input.Find("TEAMS").Text("ColourTeamB.Text"))
Value in ColorTeamB.Text is #FE1F41
Nothing happens :(
Originally Posted by: FlorinU  API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA",Value:=Input.Find("TEAMS").Text("ColourTeamB.Text"))
Nothing happens :( Just a guess based on so much information given like a screenshot of the title editor and such: is this really the name of the textfield ? "ColorTeamA"
[img=https://qf70pfk.sharing.bublup.com/ui/landing_page?item_id=001-i-3e9cdee6-2b77-4f67-9564-255314dd41e3]Snap[/img]
Originally Posted by: FlorinU  [img=https://qf70pfk.sharing.bublup.com/ui/landing_page?item_id=001-i-3e9cdee6-2b77-4f67-9564-255314dd41e3]Snap[/img] Like i said ( guessed) before , it's not ColorTeamA ! look at what you used for the B one ;-)
OK, the code is this: API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamB.Text")) Value in B is: #F91F41 And A gets an 8 zeroes Hex code that sets alpha 0. https://qf70pfk.sharing....2-4463-869a-626e2bbcc708I am stuck here for 5 days. Any idea? Thanks
Originally Posted by: FlorinU  OK, the code is this: API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamB.Text")) Value in B is: #F91F41 And A gets an 8 zeroes Hex code that sets alpha 0. https://qf70pfk.sharing....2-4463-869a-626e2bbcc708I am stuck here for 5 days. Any idea? Thanks you want to have the text in ColorTeamA.Text to be the color that you specified by code in ColourTeamB.Text. this is what this script line is doing. are you running/excecuting the script ? On the other hand if you want the color of the text to match the code that is written in the text field then use the same textfield twice Code:API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamA.Text"))
I need option A Yes, I am running/executing the script, that's exactly what gets me to the 8 zeroes
Would you give it a try at that script?
Thanks.
F
Originally Posted by: FlorinU  Would you give it a try at that script?
Thanks.
F
Any Script i post has been tested first! The result you are getting does not make sense , or some information is missing in what you are doing or trying to do
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: FlorinU  OK, the code is this: API.Function("SetTextColour",Input:="TEAMS",SelectedName:="ColorTeamA.Text",Value:=Input.Find("TEAMS").TEXT("ColourTeamB.Text")) Value in B is: #F91F41 And A gets an 8 zeroes Hex code that sets alpha 0. https://qf70pfk.sharing....2-4463-869a-626e2bbcc708I am stuck here for 5 days. Any idea? Thanks Hint: Don't mix American and British English in scripts! ;)
 2 users thanked dmwkr for this useful post.
Rookie mistake, my bad, now I understand why suddenly it started working (no colo(ur) in the names)
However, vMix has this also mixed in the colo(u)r functions for Title: "SetColor" and "SetTextColour" :)
Thanks for the help!
