guildenstern
#1 Posted : Tuesday, March 15, 2022 3:28:54 PM(UTC)
guildenstern
I am working on a project that contains media of different aspect ratios. Importing a 1080 x 1080 .avi file into a 1920x1080 60fps projects appears stretched. i've tried toggling between Normal and Source in the input's general settings, but it remains the same.
has anyone figured out a solution?
MartLeib
#2 Posted : Tuesday, March 15, 2022 4:28:30 PM(UTC)
MartLeib
Estonia
Under input settings, Position set Zoom X to 0.5625
You can calculate this value. Just divide video width by 1920. In your case 1080/1920=0.5625
