coskel22 wrote:You may have just saved my life!
:) off to download and test
UPDATE: love this. I did a quick test and it played out perfectly in 12.0.0.129 Is there a way to load RTMP streams into the scheduler? Yes... its a very simple process... thus: 1. Click on Add Input 2. On the Input Dialog pop up, choose Flash/RTMP tab, add your RTMP URL. if it appears and its showing... 3. Rename it as you desire... its case sensitive e.g BBC-LONDON by clicking on the cog and change the name under name just above Aspect Ratio in the General menu 4. Now on the vManager, click on the Input under the Add Event and put the Input name into the Title Area e.g. BBC-LONDON That's it in my own simple way... Do not hesitate to drop by should you need more clarifications. SCREENSHOT HERE:
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
I am using rtmp://SERVER/vod/NAMEOFFILE.mp4 and it doesn't seem to work. UPDATE: I see in the documentation that RTMP only works with live.
What about archived streams that are on the RTMP server and not hosted locally? How do I input those?
Is anyone able to clarify if the scheduler will work with archived files using RTMP?
Joined: 5/16/2014(UTC) Posts: 6 Location: Dominica 767
i can't get the download file can anyone give me an working link?
cannot find vMix, It is displayed "OFFLINE".and "can't access http://127.0.0.1:8088". but access to vMix by browser, i can access remote pane normaly. vMix scheduler does not work at Windows8.1?
escribo en español no se ingles si alguien lo traduce lo agradezco mi consulta es, sera muy complicado hacer que el vmixscheduler capture las entradas del vmix, uno genera las entradas en el vmix y las agrega según vaya configurando la programación así luego se pueden borrar asi cuando tengan que salir al aire automáticamente se cargarían cuando se estaría ejecutando le vmixscheduler creo que seria mas fácil que tener que agregar todas las opciones de entradas del vmix, no se si es posible solo se me ocurrió por lo que necesito
muchas gracias
@ clair I cannot confirm whether or not the schedulers work with Windows 8.1 (I'm on Windows 7). There were issues noted if system was not running Framework .net 4.0 (check page 3 of this thread) Have you tried both versions? (macjaeger's and AMP's) Are you running both the Controller and Manager applications? (you need them both to be running)
@ mscompagnoni If I understand you correctly, you are describing precisely how the scheduler works... It automatically adds the inputs about 10 seconds prior to going "On Air" and deletes them shortly after use. You do not have to pre-load anything into vMix. As long as you have a valid path to your input you are good to go!
gracias ice por responderme lo que vos decis ya lo se bien , yo digo no seria mas fácil cargar las entradas en vmix y que el vmixscheduler las tome del mismo por ejemplo con las entradas flash o rmtp o las rtsp o un entrada de audio poder agregarle a otra entrada como audio que todavía no soporta el vmixscheduler o para poner los títulos
desde ya muchas gracias martin
@ mscompagnoni Sorry for misunderstanding, the translation does not communicate very well what you are requesting or suggesting. Can you describe a simple scenario that helps me to understand? As near as I can figure (from the translation) you are suggesting it would be nice to be able to load inputs from the scheduler to vMix as you need them??? as well as automatically on a schedule, such as a title overlay (which is not currently possible). Am I close?
el ejemplo es el siguiente agrego entradas directamente en el vmix por ejemplo una corriente rtmp y tambien una imagen y le superpongo un entrada de audio para que la imagen tenga sonido entonces con el scheduler tomo esas entradas y solo configuro para que durante 10 minutos muestre la corriente rtmp y luego otros 10 minutos de la imagen que tiene asociado la entrada de audio
example is the following add entries directly into the Vmix such as an rtmp stream and also an image and superimpose one audio input for the image to have sound then the scheduler take those tickets alone I set for 10 minutes showing the rtmp stream and then another 10 minutes to the image having associated audio input
gracias martin
It looks like to having a bug in this application.
vMix scheduler cannot connect to vMix, when using "title" at Multi byte letters. then remove "title", scheduler can connect to vMix.
i using scheduler without "title" now.
Joined: 9/16/2013(UTC) Posts: 27 Location: Lagos, Nigeria
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
My tests have found vScheduler works well with vMix 12, as confirmed by Martin. I'll address a few questions that have been asked as well:
1) VScheduler communicates via web interface on the same computer with vmix. Is it possible to redirect vscheduler to an other ip address to manage vmix over internet or local network? a. It is 100% possible, just not with vScheduler or vMixScheduler. They are both hard coded to look at localhost, however this can be changed.
Can you please explain the above post further, because I have try it several times but I could not locate space to insert the vmix system IP.
Best Rgd, GBIM
GBIM wrote:My tests have found vScheduler works well with vMix 12, as confirmed by Martin. I'll address a few questions that have been asked as well:
Best Rgd, GBIM
They are currently coded to only look at a local address, you can change this by downloading the source code and recompiling. There is no way to do it in the actual program currently. Unfortunately, at this time we are no longer using vScheduler, so I can't offer any promises to add feature in. As a sidenote: Yes, vScheduler works perfectly fine under Windows 8 and 8.1.
 1 user thanked AMP2TV for this useful post.
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
macjaeger wrote:Ok, fine! Then it should be not that hard to implement the features asked for. Yet if you want me to do it, i can't do it before april, my schedule is more than full atm. you can control the overlay channels from the api /api/?function=OverlayInput1&Input=1 (works as a toggle) and as for changing text /api/?Function=SetText&Input=1&SelectedIndex=0&Value=hello Was this feature added? If so, where is the file? Thanks
is the loop function added? so it wil start from the beginning when at the end and not just stop because i have to manually make a new playlist or something like that
So it looks like it still is localhost only?
Can someone verify if it can read from a remote webserver? yes or no?
thanks!
Scheduler is finish ? No updates?
