Hello For the life of me I cannot get certain shortcuts to work in vMix. Specifically, the options under the input windows like Close, Quick Play, Cut, Loop. and the Pause/Play button. I have tried both keyboard shortcuts and Stream Deck shortcuts. I don't have problems with other shortcuts like sending inputs to outputs etc, just these ones that exist under the input preview windows. I really want a shortcut for the Play/Pause button to work. What am I doing wrong? Thanks
I wish to pause a camera input before transitioning to another input. Pressing the pause symbol on the input with a mouse works fine but trying to use a shortcut such as:
Settings\shortcuts\general Key/Control = Space Function = Pause Input= 1 HP HD Camera It makes no difference if "Assign Shortcut to Input Number" box is ticked or not.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
I think this is the shortcut function LivePlayPause.
