Is it a good idea to use this device to show a broadcast to a commentator and camera operators? At the same time, it would act as a tally( Four smartphones/tablets can be used as video receivers from up to 492' away (line of sight))for the camera operator. It also has audio included. Any thoughts? https://www.bhphotovideo...g_wireless.html/overviewJiii
Joined: 9/10/2015(UTC) Posts: 133 Thanks: 2 times Was thanked: 35 time(s) in 32 post(s)
Your biggest challenge would be latency. At 60ms it would be unusable / a distraction for camera operators.
The commentators could make use of it as long as it's not an issue for them to have a bit of latency (such as being in a separate room where they can't even see the event.) The only real benefit of this is that all the transmission is done in a single box. This would really not be that different from using a vMix SRT output, a wireless access point, and then having phones/tablets watching that stream (with the benefit of not being limited to only 4 devices).
