Beta Discussion
Zoom support for Cameras / Calls / Audio Inputs NDI feeds
I have been testing the Zoom integration in the vMix 27 Preview release and while I can get Zoom feeds to go to the dedicated four NDI outputs, however if I enable the "Cameras / Calls / Audio Inputs" option in the next section instead, I do not get those inputs as NDI sources.
Would it be possible to add support for Zoom inputs to the "Cameras / Calls / Audio Inputs" feature so that we don't have to burn the dedicated NDI outputs for Zoom use?
Thanks! Great work, by the way!
Joined: 1/13/2010(UTC) Posts: 5,163 Location: Gold Coast, Australia Was thanked: 4176 time(s) in 1499 post(s)
No, unfortunately for technical and performance reasons there will not be a direct NDI output option available for Zoom inputs in vMix.
If you require using raw Zoom sources elsewhere over NDI, then you will need to look at a dedicated solution like Zoom ISO or Zoom Rooms.
Thanks for the confirmation!
Joined: 3/30/2023(UTC) Posts: 55 Location: Chicago Thanks: 8 times Was thanked: 2 time(s) in 1 post(s)
Disappointed in this, but if it's got to be, it's got to be.
Beta Discussion
