AElfTech
#1 Posted : Wednesday, October 25, 2023 3:12:50 PM(UTC)
AElfTech
I have been testing the Zoom integration in the vMix 27 Preview release and while I can get Zoom feeds to go to the dedicated four NDI outputs, however if I enable the "Cameras / Calls / Audio Inputs" option in the next section instead, I do not get those inputs as NDI sources.
Would it be possible to add support for Zoom inputs to the "Cameras / Calls / Audio Inputs" feature so that we don't have to burn the dedicated NDI outputs for Zoom use?
Thanks! Great work, by the way!
#2 Posted : Wednesday, October 25, 2023 6:16:43 PM(UTC)
Was thanked: 4174 time(s) in 1498 post(s)
No, unfortunately for technical and performance reasons there will not be a direct NDI output option available for Zoom inputs in vMix.
If you require using raw Zoom sources elsewhere over NDI, then you will need to look at a dedicated solution like Zoom ISO or Zoom Rooms.
AElfTech
#3 Posted : Wednesday, October 25, 2023 6:25:52 PM(UTC)
AElfTech
Thanks for the confirmation!
fgolman
#4 Posted : Sunday, October 29, 2023 5:20:11 AM(UTC)
fgolman
Disappointed in this, but if it's got to be, it's got to be.
