gilar
#1 Posted : Friday, September 4, 2020 4:12:08 AM(UTC)
gilar
Indonesia
Was thanked: 7 time(s) in 4 post(s)
Hi ... i'm trying to create Simple Apps something like PlayOut
Actually it's only a client which control vMix Playlist Input in vMix Engine
The goals of this apps is to separate PlayOut Operator from vMix Engine
So vMix Operator can focus to Camera Input or another
Feature
- Load all video in Playlist input
- Select, Play/Pause, Cue, Auto Next, Loop
- Read Time Code (duration, count up, count down)
Tasted:
- Windows 10
- vMix 23.0.0.60 x64 (Trial)
How to Use
https://youtu.be/x25C0DDJ1Ow
- Open vMix Sofware
- Create PlayList Input (You can create more than 1 PlayList Input)
- Open Draco vMix PlayOut
- Type vMix IP Adress, type localhost if it's on the same Machine
- Pust vMix Button to Connect to vMix Engine
- Select Input (PlayList)
- Select Video on List
- Play It
Here's the link for those who wish to give it a try
Draco vMix PlayOut
Please let me know if you have any question
Best Regards
Gilar
Joeboe
#2 Posted : Friday, September 4, 2020 4:50:58 AM(UTC)
Joeboe
Hi, I have been testing this app, .... it is a bit sluggish in updating, but the files play even though the app has not yet updated to show the correct file being played....sometimes it will not update at all, until; the clip playing is paused or stopped....The countdown seem to be same as vMix. I wish that the inputs would show the name of the input as well, rather than just the input number only...(eg...I have a list on input 4, and the input is named PLAYER 1, I have to search for player 1 on vMix to see what the number is in order to select it)....It is a good little app, just needs some tweeking....
yakkatv
#3 Posted : Friday, May 13, 2022 1:26:04 AM(UTC)
yakkatv
Lithuania
thx for this solution can you please tell me how to load vlc live stream input
yakkatv
#4 Posted : Friday, May 13, 2022 1:39:15 AM(UTC)
yakkatv
Lithuania
playout should be give me possibility to set time for each playlist or each movie to play while this is not see any different from normal playlist function witch exit in vmix already
nikosman88
#5 Posted : Wednesday, May 18, 2022 6:51:56 PM(UTC)
nikosman88
Greece
Was thanked: 53 time(s) in 50 post(s)
You cannot do the things you say,with this programm. It is not designed for this.
You can do this inside vmix by selecting add input-->stream/srt
yakkatv
#6 Posted : Sunday, June 12, 2022 6:25:23 AM(UTC)
yakkatv
Lithuania
i try not switch .... its switch only movie on time but input with srt not
nikosman88
#7 Posted : Sunday, June 12, 2022 6:58:17 PM(UTC)
nikosman88
Greece
this program is only for vmix lists control. Cannot switch any source. But this program vscheduler https://forums.vmix.com/...ler---vMixScheduler-Fork can switch to srt source in a specific time we set
