Joined: 8/22/2020(UTC) Posts: 10 Location: Depok, West Java Was thanked: 7 time(s) in 4 post(s)
Hi ... i'm trying to create Simple Apps something like PlayOut Actually it's only a client which control vMix Playlist Input in vMix Engine The goals of this apps is to separate PlayOut Operator from vMix Engine So vMix Operator can focus to Camera Input or another Capture.PNG (1,128kb) downloaded 30 time(s).Feature - Load all video in Playlist input - Select, Play/Pause, Cue, Auto Next, Loop - Read Time Code (duration, count up, count down) Tasted: - Windows 10 - vMix 23.0.0.60 x64 (Trial) How to Use https://youtu.be/x25C0DDJ1Ow- Open vMix Sofware - Create PlayList Input (You can create more than 1 PlayList Input) - Open Draco vMix PlayOut - Type vMix IP Adress, type localhost if it's on the same Machine - Pust vMix Button to Connect to vMix Engine - Select Input (PlayList) - Select Video on List - Play It Here's the link for those who wish to give it a try Draco vMix PlayOutPlease let me know if you have any question Best Regards Gilar
Hi, I have been testing this app, .... it is a bit sluggish in updating, but the files play even though the app has not yet updated to show the correct file being played....sometimes it will not update at all, until; the clip playing is paused or stopped....The countdown seem to be same as vMix. I wish that the inputs would show the name of the input as well, rather than just the input number only...(eg...I have a list on input 4, and the input is named PLAYER 1, I have to search for player 1 on vMix to see what the number is in order to select it)....It is a good little app, just needs some tweeking....
thx for this solution can you please tell me how to load vlc live stream input
playout should be give me possibility to set time for each playlist or each movie to play while this is not see any different from normal playlist function witch exit in vmix already
Joined: 12/24/2021(UTC) Posts: 351 Location: athens Thanks: 113 times Was thanked: 53 time(s) in 50 post(s)
You cannot do the things you say,with this programm. It is not designed for this. Originally Posted by: yakkatv thx for this solution can you please tell me how to load vlc live stream input You can do this inside vmix by selecting add input-->stream/srt
i try not switch .... its switch only movie on time but input with srt not
