Instant Replay
How to copy current state of IR - A to IR - B
I'd like to be able to setup a replay on IR - A (in Preview), then hit a button which activates a shortcut or script that transfers the input from IR - A to IR - B, then displays IR - B in the Live window. I'd then be able to setup another replay in IR - A (Preview) while IR - B (Live) is playing and repeat the process.
Is this possible?
Josh
If you'll know is this possible - then will share your answer with me! we are working in good company EWriting asay https://ewriters.pro/ and we are also interested in it! thnx
Joined: 12/27/2012(UTC) Posts: 5,091 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Are you talking about A and B as being different replay events or the A and B replay windows ?
Also have you checked the shortcut reference list (warning , it's a long one)
Instant Replay
