Josh
#1 Posted : Wednesday, February 12, 2020 6:07:47 AM(UTC)
Josh
I'd like to be able to setup a replay on IR - A (in Preview), then hit a button which activates a shortcut or script that transfers the input from IR - A to IR - B, then displays IR - B in the Live window. I'd then be able to setup another replay in IR - A (Preview) while IR - B (Live) is playing and repeat the process.
Is this possible?
Josh
VJack
#2 Posted : Wednesday, June 3, 2020 3:16:42 AM(UTC)
VJack
If you'll know is this possible - then will share your answer with me! we are working in good company EWriting asay https://ewriters.pro/ and we are also interested in it! thnx
#3 Posted : Wednesday, June 3, 2020 3:30:52 AM(UTC)
Was thanked: 921 time(s) in 760 post(s)
Are you talking about A and B as being different replay events or the A and B replay windows ?
Also have you checked the shortcut reference list (warning , it's a long one)
