Feature Requests
Intergrate vmix call on website via iframe or other option
Joined: 7/5/2019(UTC) Posts: 28 Location: Sydney Was thanked: 5 time(s) in 4 post(s)
I want to build a page with vmix call side by side with "internet clicker". This will allow remote presenters to advance a powerpoint deck remotely.
I havent had any luck embbeding vmix call using a iframe. Not sure if it's due to not having access to the "allow camera" or if webRTC doesnt work with iframes.
I would like a option where we can embed vmix call into a webpage, which will allow us to put it side by side with other tools for remote presenters. Maybe some kind of API or embedding code.
Joined: 7/10/2020(UTC) Posts: 33 Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Check this https://forums.vmix.com/...x-Call-iFrame#post81382. Of course as I said in this topic above the best way is vMix to create a complete API for that that contains HTML / Javascript API that without iframe recreate their service on our websites controlling the options for example enable/disable chat/shareware or allow only to shareware etc. Also a complete API to remote control a vMixCall input in this areas at least : - Control remotely call quality (video/audio) and all other settings that can changed. - Request a new password for this input to change callers dynamically without the need click on "CHANGE" on input settings. - Get this password, vmix.at link and other info through XML/XMLTEXT command This will help as to build professional services through vMixCall platform.
Joined: 6/10/2020(UTC) Posts: 2 Was thanked: 1 time(s) in 1 post(s)
It is pretty simple if you have control of your Apache or Nginx server. With just a few directives you can use your 'white label' domain like https://call.company.com?call.aspx?Key=3275262048&Name=Presenter1. For remote clicker control we use Cliqer.io (https://cliqer.io) and very happy with it.
1 user thanked protogon for this useful post.
Thanks, guys. I was looking for the same information.
Check if the website is not a scam. It could be.
Feature Requests
