carlofornasari
#1 Posted : Tuesday, August 25, 2020 5:16:28 PM(UTC)
carlofornasari
I want to build a page with vmix call side by side with "internet clicker". This will allow remote presenters to advance a powerpoint deck remotely.
I havent had any luck embbeding vmix call using a iframe. Not sure if it's due to not having access to the "allow camera" or if webRTC doesnt work with iframes.
I would like a option where we can embed vmix call into a webpage, which will allow us to put it side by side with other tools for remote presenters. Maybe some kind of API or embedding code.
tsioukas
#2 Posted : Wednesday, August 26, 2020 10:13:53 PM(UTC)
tsioukas
Greece
Check this https://forums.vmix.com/...x-Call-iFrame#post81382.
Of course as I said in this topic above the best way is vMix to create a complete API for that that contains HTML / Javascript API that without iframe recreate their service on our websites controlling the options for example enable/disable chat/shareware or allow only to shareware etc.
Also a complete API to remote control a vMixCall input in this areas at least :
- Control remotely call quality (video/audio) and all other settings that can changed.
- Request a new password for this input to change callers dynamically without the need click on "CHANGE" on input settings.
- Get this password, vmix.at link and other info through XML/XMLTEXT command
This will help as to build professional services through vMixCall platform.
protogon
#3 Posted : Sunday, September 20, 2020 1:49:01 AM(UTC)
protogon
It is pretty simple if you have control of your Apache or Nginx server.
With just a few directives you can use your 'white label' domain like https://call.company.com?call.aspx?Key=3275262048&Name=Presenter1.
For remote clicker control we use Cliqer.io (https://cliqer.io) and very happy with it.
thanks 1 user thanked protogon for this useful post.
andreadistefano on 12/9/2020(UTC)
Martinzo
#4 Posted : Monday, July 26, 2021 9:22:16 PM(UTC)
Martinzo
Thanks, guys. I was looking for the same information.
ChristaEchard
#5 Posted : Monday, July 26, 2021 11:24:09 PM(UTC)
ChristaEchard
Check if the website is not a scam. It could be.
