Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
From vMix go to Settings -> About and click Send Support Report Then email us your product key and we will be able to look up the report and see what is happening.
Thanks,
Martin vMix
Rank: Guest
Groups: Guests
I tried something and I do not know what is going on here...nevertheless, I was using Magic codec to record, but found that it drops frames a lot lately.....but Canopus codec seems to work better....now I am editing, if i cut the video, it goes back in sync...yes, it sounds crazy, but I have to cut the video every 10 or 15 mins, and the sync comes back.....I will check on my HD to see if it is the drive I am using.....I had this before with an external drive with long clips.....I will do a similar length recording using a different drive to see what happens.....
Joined: 2/18/2014(UTC) Posts: 1,821 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
In at least 16.0092 and .0014 there is a clicking noice when the equalizer is adjusted in the audio settings. A bug or something that can't be avoided?
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
richardgatarski wrote:In at least 16.0092 and .0014 there is a clicking noice when the equalizer is adjusted in the audio settings. A bug or something that can't be avoided? I have the same problem. Happens also with the new 17 beta. Chap
Joined: 5/20/2015(UTC) Posts: 493 Location: Copenhagen, Denmark Thanks: 382 times Was thanked: 100 time(s) in 79 post(s)
I experience the same problem too, with a little clicking noise on adjusting the equalizer. richardgatarski wrote:In at least 16.0092 and .0014 there is a clicking noice when the equalizer is adjusted in the audio settings. A bug or something that can't be avoided?
