	Feature Requests
	Select midi keys from advanced shortcuts screen
 Joined: 1/15/2017(UTC) Posts: 45 Location: Exeter, UK
  Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
                Having bought an X-keys device most of my shortcuts are now midi notes. Now I have started to use the advanced option on shortcuts it now does not let me select my existing midi assigned shortcuts (slightly defeating the point of the feature in my opinion). I appreciate that the dropdown would not be big enough so why not use a 'find' button as per the main shortcut set-up.
  It would also be very useful to be able to add a 'blank' shortcut that could just call existing shortcuts in the advanced option. This again would stop unnecessary duplication.
  One final tweak would be to have some sort of an indicator as to if there are any further shortcuts triggered after the main shortcut when you are not on that screen (maybe a number in brackets after) so you can tell what else is in action without having to check.
  Alex
	Feature Requests
