Stream input - output question
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Hi, I need some info on something that i might need to achieve in next months. I wil have a van gathering and mixing images in a certain location with a vmix system, the van will have satellite connection to the internet. But i don't want to transmit directly to my CDN, instead i would like to receive that stream and use it as an input in vmix in a studio with presenters etc... and then send that stream to my CDN as a live broadcast. I suppose i need to set the pc in van as if it were a server, and once I know it's ip and have dealt with satellite NAT i could access the stream form the studio...
Other necessity is to stream to LAN as well as broadcasting on the internet. Usually there are lots of people on location that use the same internet connection i use to stream to watch it.. and this is a big waste of precious bandwidth, plus they get the internet delay.. is there an easy solution for this with FMLE or other ?
