Hello, it's possible create a live rtsp stream for stream hosting that receive only a rtsp flux? Thank you Al.
Hi Pagu
it's possible with an external RTSP encoder, like FFMPEG or VLC for example.
Simply use EXTERNAL virtual devices to feed this external encoder with vMix out.
Guillaume
Hello Dwam, have you a guide or steps? first i use a vmix external for create a virtual device, and after?
Open vMix virtual device with VLC (as a capture device). Make sure you have image and audio.
Then look for RTSP streaming examples in Google. You should find easily how to do it with such keywords "stream rtsp vlc"
