vMix Call
Can vmix design a ipad app for a vmix call from a ios device?
Groups: Guests
That would be great and probably not to hard.......but I don't know app programing
Joined: 3/30/2014(UTC) Views messages in topic : 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Yes that would be great for iPad, is there a programmer out there can do this.
I for one would use it.
You'd better ask Apple to support natively WebRTC which is an open standard designed to work out of the box in a compliant browser!
Groups: Guests
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
Quote:Can vmix design a ipad app for a vmix call from a ios device? it certainly would be possible - there are already dedicated WebRTC apps from other vendors in the app store for iPad - in particular "appear.in" http://appear.in is very similar to VMix call - but has its own end-portals which are not 'linked' to the VMix call portal, although technically its doing exactly the same thing. They have a free iPhone / iPad app The existence of this app illustrates how WebRTC certainly can be implemented on iOS - perhaps using dedicated code rather than within an existing browser framework. However, it might be difficult to justify such a development for a low cost app for a relatively small market, especially when Apple's actions suggest that the in-development webkit support for WebRTC might roll out to iOS at some point in the future, rendering a custom app obsolete. On a related note - when the NDI.Cloud free public beta starts, there will also be an NDI.Cloud iPhone 'sender' app which will push the camera from an iphone/ipad as H.264 into the NDI.Cloud network and it will pop-out at the destination as NDI. It wont have the same return feedback as the VMix call interface, since NDI.Cloud is designed for a different target purpose (studio to studio with always-on and controllable quality), but it will provide this sort of base mobile functionality for those who require it. http://ndi.cloud
Hi!
Yep I know that Mark. But the point is precisely to keep out of "apps" or "dedicated code".
Guillaume
vMix Call
