vencodigital
#1 Posted : Friday, March 17, 2017 9:09:19 AM(UTC)
vencodigital
Hallo annywhere
I`m new at linear edditing, after 20yers non-linear edditing.
Problem is: NO VIDEO signal in vMix. Capture card is Decklink Mini Recorder 4K and Intensity Pro 4K, in BM Media Express all OK, Cable connection OK, vMix v18 Trial.
#2 Posted : Friday, March 17, 2017 9:55:30 AM(UTC)
Hi
if you have sound out of the decklink card in vMix, then try changing the video format when selecting video input.
If you've got signal into Media Express there is no reason why vMix should not get it, it's only an initial config to find.
