nickstuy
#1 Posted : Tuesday, March 14, 2017 3:29:40 PM(UTC)
nickstuy
When i turn on the external output by using NDI, and i use Newteks NDI connect pro (that support fill and key) Does is work with fill and key ? I want to use vmix as a CG software by using different broadcast video mixers (not a tricaster).....  (pc specs : i7 gtx1060 and Blackmagic DeckLink Quad 2).
Thremir
#2 Posted : Tuesday, March 14, 2017 5:00:04 PM(UTC)
Thremir
Yes, if you run NDI Connect and vMix on separate computers
https://forums.vmix.com/....aspx?g=posts&t=9640
