Rank:: Advanced Member
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
I'd like to see the ability to choose more than 2 preview rows. I have a 24" 1920x1200 monitor that can rotate to be 1200x1920 This would be perfect for adding 4 to 6 more rows. Also it would be great to have the Top preview and program out display have a bounding box (just some light colored rectangles) so we can tell at a glance if the source fits properly or not along with displaying the setting i.e. 720x486 30fps, 1280x720 59.94fps I can upload a moch up if needed. Thanks
Joined: 12/2/2011(UTC) Posts: 77 Location: Europe / The Netherlands
Hi, I'll suggest also to read the topic about vMx and dual screen. read hereI think there is some overlap with your request. Regards, Hanno
Hanno, I'm aware of that request and think it too is a good idea. I was just thinking that this one may be easier to obtain. Also there can be video overlay issues when spreading across two monitors. If you want to see what I mean connect a second monitor with Vmix on number one then open Flash Media Encoder and drag it to the second monitor. This works okay on some video cards but not most. Thanks for your input.
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
I was experimenting with another display product of ours that has it's screen rotated 90 degrees and thought exactly the same thing, how cool would it be if i could use all that screenestate for input selection.
so +1 for more input rows from me:)
M@ik
+1
- and along those same lines regarding screen estate... What about being able to hide, minimize or collapse, or even move to a tabbed or foldered window those inputs that do not need to be monitored or accessed regularly?
