call api?Function=ReplayPlayEventsByIDToOutput&Value=
then a inputbox on vmix comes up and ask for the IDs
I do the call in error, but as long as the inputbox is open, you can't work any longer with vmix until you press cancel on the box
same situation for api?Function=ReplayPlayEventsByID&Value=
