kol0
#1 Posted : Wednesday, March 1, 2017 8:54:55 AM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
Add shortcuts to Position in MultiViewOverlay
Code:
SetMultiViewOverlayPanX
Change current PanX value of MultiView Overlay for Input at Index
Value,Input,Index
Also for any parameter in Position TAB in input settings
Zoom, ZoomX, ZoomY PanY, RotateX, RotateY, RotateZ, CropX1, CropX2, CropY1, CropY2
Example of use.
You have cropped caller video. He move left/right during the show. Now to fix position you need change cropX1 and cropX2 and pan input. And must do it on good precision so you not go out frame you have made.
With shortcut you can do it on one button.
{Caller is in input 3 index 2(multiview two)}
Add button with three change in one click.
SetMultiViewOverlayPanX,+1,3,2
SetMultiViewOverlayCropX1,-1,3,2
SetMultiViewOverlayCropX2,-1,3,2
Know problems.
Pan is not in pixel value its % of screen.
Crop is in pixel not in % of screen.
Mayby add PanXpx to pan in pixel insteed of percent of screen.
richardgatarski
#2 Posted : Friday, March 3, 2017 9:15:00 AM(UTC)
richardgatarski
For your particular need, would it not be better to make the adjustments in the original Input (or a virtual copy of it)?
Or, ask the person to move to a better position ;)
