Feature Requests
Virtual audio in- and outputs - to replace 3.rd part virtual cables.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
I've just realized that most vMix users I know, uses at least one - if not several, virtual audio cables for their setups.
Why not add this feature directly into vMix, in much the same manner as the two virtual camera outputs?
I wouldn't think it to be too difficult to have: - each of the 4 vMix audio busses appear in Windows as virtual outputs (Appearing in Windows as a Microphone/line-in device). and in the same manner: - the ability to add an input that is seen in Windows as an Audio output (Speaker/Line-out device).
This way, a lot of users would be able to simplify their setups, making configuration easier and less prone to both user- and technical errors.
Best
JonL
Feature Requests
