Feature Requests
replay camera from in point with one button
In instant replay vmix uses toggle shortcuts to replay different camera angles. It is useful to play cameras from in point with one button. A shortcut for this will be appreciated.
Thomas
It is very difficult to understand what you want with just one sentence..
As I understand it, the functionality you try to achieve can already be achieved in vMix.
Setting up multiple functions for same button, e.g. functions: 1) creating a new replay clip, 2) set toggle camera (angle) #1 on latest replay clip 3) set toggle camera (angle) #2 on latest replay clip.
Then you have achieved a clip with camera (angle) #2 ONLY active for that clip.
/ Jens Stigaard
The current workflow with 4 cameras is this: you mark in a certain point for exaple with camera 2. If you want to play camera 3 from the certain in point you should toggle camera 3, untoggle camera 2 and play the selected clip. I tried to make a shortcut to play the camera angle I want with one button but it is impossible because you never know what camera is toggled before. If they can make a shortcut for this it will be very helpful especially in sports broadcasting where the speed matters
Yeah you are right, I've experiences once that the camera 2 was the default angle, but that was Perhaps because I've had that camera in replay preview A.
So your request is to have the camera 1 angle always as default angle when new clips are created?
Im going to post a video from an evs server so you understand what exactly I want
this is the video that present the workflow of the replay in evs server. when you press camera a,b,c video returns to the in point and plays again.
Rank:: Advanced Member
Groups:: Registered
I think it would be great to have a shortcut for SetCamera1,2,3,4 which switches off all the other angles of the selected event so you only need one click to go to the cameraangle you want
+1 xaver wrote:I think it would be great to have a shortcut for SetCamera1,2,3,4 which switches off all the other angles of the selected event so you only need one click to go to the cameraangle you want
Feature Requests
