Thanks: 74 times Was thanked: 4 time(s) in 3 post(s)
I know and read that vMix can transport Stream over TCP Pull "Select this option to connect to a remote Transport Stream server such as the Teradek Sputnik using the TCP protocol. Enter the hostname and port of the remote Transport Stream server"
But I tried several times to input TCP from my Sputnik server without any signal :( Maybe I used wrong port - in input [TS over TCP Pull] which is correct? 1935,5111... Maybe I need to enter "go live" on Bond?
Someone uses this now with success?
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
it is easy, in stream type: transport stream over tcp pull, hostname the ip or the hostname of your sputnik wihout http:// only yourdomain.com or XXX.xxx.XXX port: the port that you put in the sputnik in ts server, default 5000 or 5030 i not remember
to check in vlc tcp://hostname:port or in ffplay/omxplayer(android) http://hostname:port but for my work much better a external decoder, have lower delay and less pixelations-freezen. the teradek base not is also the best decoder for as
Thank You dark_ata, but I still can not set my Bond to activate ts server - should I buy mpeg-TS plugin from Teradek (500$) ?
