Cormac
#1 Posted : Thursday, February 9, 2017 12:47:04 PM(UTC)
Cormac
Hi There .
One of my computers only has usb 3 inputs.
Does anybody know if vmix can see the atem usb output ?
Or if not is there any other device like the BM intensity that will be seen by vmix on a usb input?
Otherwise I was thinking.....
of trying to take the vmix into the atem and was wondering if the overlay lower thirds and vmix social would work with transparency properly this way?
Regards
Cormac
#2 Posted : Thursday, February 9, 2017 12:57:26 PM(UTC)
Hi Cormac
No it won't see it by default.
An option would be to use MXPTiny which allows to preview AtemTS in VLC which can provide the feed to vMix using NDI plugin for VLC.
See:
http://www.atemuser.com/...order-previewer-streamer
http://www.newtek.com/ndi/applications
Yes. Check Magewell or Inogeni USB dongles
http://www.magewell.com/
https://inogeni.com/
Then you can output your ATEM using SDI or HDMI to vMix.
Guillaume
