Harty
#1 Posted: : Thursday, February 9, 2017 8:02:45 AM(UTC)
Harty
Was thanked: 10 time(s) in 7 post(s)
I´m trying to build a "poor mans ptz" with a korg nanokontrol midi device. When using its faders as shortcuts for the t-bar or volume knobs in the audio section it works great so I thought I could maybe also use it to control the Zoom and Pan X/Y for a virtual input. In my case I´m using a 4K Input and want to move the virtual input which is zoomed up to factor 3 "live"... BUT: the numbers in the Zoom have a lot of numbers after the "," (sorry, don´t know the english word for this kind of numbers) which can not be controlled via midi, as this only sends 1-127... Is there any workaround for this?
Thanks in advance and greetings, Thomas
nashenden
#2 Posted : Friday, February 17, 2017 5:05:23 PM(UTC)
nashenden
I'm no expert, but if you only have a resolution of 0-127 will this be precise enough to adjust a (zoomed) PTZ head? proper ones go down to 0.01 degrees or so for fine movement?
